Backhoe BT 750 Arm Won't Swing - need to move manually
   / BT 750 Arm Won't Swing - need to move manually #1
rscorey
I'm back again with my BT 750 that won't swing side to side. It is all the way to the left and I need to get it centered to take it off the tractor so I can mow and do other chores. Since it won't go from the control panel in either direction (all other functions work) how can I relieve the pressure or what else can I do to manually move it to the centere?
Probably an easy question but I don't know about hydraulics.
Thanks,
Scott
   / BT 750 Arm Won't Swing - need to move manually #2
examine if there is Blockage in the hoses on Swing Cylinders, which should be underneath the seat and oil tank, i think.
   / BT 750 Arm Won't Swing - need to move manually #3
Has the joystick linkage come apart?
Kim
   / BT 750 Arm Won't Swing - need to move manually #4
Corey,
Do you have solenoids on the valve stack? If so, this was an Auto Swing backhoe and a kit used to be available to convert it to mechanical control.
These kits are long gone and you likely will do well to find a like sized machine in a tractor parts yard and put it on your hoe.
Good luck!
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
