Backhoe BT751 weight? Removing Boom cylinder.
   / BT751 weight? Removing Boom cylinder. #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Can someone supply the weight of the BT751 BH? I need to lift the boom enough to swing the boom to one side, so as to remove the boom cylinder for servicing. This is a backyard deal, not a shop floor, so I am improvising.
The swing cylinders are already out, so it should swing easily (sure) once the weight is off. I am a bit concerned about the unit tipping if I do that though.
   / BT751 weight? Removing Boom cylinder. #2
Hi Joe, this might be a little late to help you, but I found a weight of 892 pounds for the BT751.
John Deere 72" Bucket (A46443)
John Deere 72"...
TPM 40' Container (A47809)
TPM 40' Container...
2017 VOLVO VNL64 T300 DAY CAB TRACTOR (A43005)
2017 VOLVO VNL64...
3000 Gallon Black Poly Water Tanks (A45336)
3000 Gallon Black...
2011 SAND SEPARATOR (A47001)
2011 SAND...
7x16 Ag Tires (pair) (A47809)
7x16 Ag Tires...
