bubbling in expansion tank
   / bubbling in expansion tank #1
roger leblanc
kioti ck30h
2004 kioti ck30h could it be a head gasket machine has 1200 hours
   / bubbling in expansion tank #2
That would be my best guess. Could be a crack in the cylinder wall but the head gasket would be my prime guess. Crack in the gasket between the cylinder and water jacket in the block will allow the hot air to be forced into the cooling system on the compression stroke. If the machine was ever over heated it's possible that the head might be slightly warped.
   / bubbling in expansion tank #3
To be certain what you are seeing is combustion gas auto supply stores sell a chemical to put in coolant which turns a certain color in the presence of combustion gases.
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
2015 DODGE RAM...
2015 CASE 580N (A47477)
2015 CASE 580N...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
