bucket chain hook alternative
   / bucket chain hook alternative #1
gerard
Veteran Member
Syracuse NY
Kubota L2500DT w/FEL
Here's what I made instead of welding/bolting three chain hooks on the top of the bucket. It's a heavy piece of 3 inch angle iron. Used a grinder to cut the slots, drilled some holes and bolted it to the top of the bucket. Works the same as a clevis hook and has the added benefit of beefing up the top of the bucket and distributing the pulling force along the length of the angle iron. I don't think my tractor has the ummph to bend this setup. Just an idea for the welding challenged :)
   / bucket chain hook alternative #2
Should be OK as long as your loader can't bend it, also make sure you don't roll the bucket forward to far when you have a loaded chain on it, chain could slip out, but that could happen to any vertical mounted chain hook, like mine.
Good luck,
JB.
Neither issue is a problem, even all the way rolled forward the chain can't slip out and the angle iron is unbendable with the tractor power/traction. The wheels will spin when pulling and with only 800 lb lift capacity I can't life enough to bend the top lip of the bucket like I've seen done opn a lot of other tractors that just weld a hook to the bucket, concentrating all the weight to a small area
Looks like your bucket is double walled on the top and so is a lot sturdier. My bucket just has the curled lip but is pretty thin and bendable otherwise. I've seen too many buckets bent because just welding a hook concentrates all the weight on a small area.
   / bucket chain hook alternative #5
jb4310,
I love that receiver hitch on the bucket. I'm gonna build me one. Wonder how much weight it will take before the top of the bucket tries to bend?
   / bucket chain hook alternative #6
2017 Ram 1500 Crew Cab Pickup Truck (A46684)
2017 Ram 1500 Crew...
2024 AmeriTrail TC18610-70E T/A Cool Down Trailer (A45336)
2024 AmeriTrail...
2012 Ford FX2 F-150 Crew Cab Pickup Truck (A46684)
2012 Ford FX2...
FLARE STACK (A47001)
2003 VIKING TRAILER CEMENT MIXING TRAILER (A47001)
2003 VIKING...
NEW Wolverine 3PT Hitch Receiver (A48289)
NEW Wolverine 3PT...
