Front-End Loader bucket compatability
   / bucket compatability #1
Mule5023
Boone
Kubota L2900
I have a Kubota L2900 with a LA 480 loader, I need to replace the 60in bucket on it and am having a hard time finding a used one. What other buckets are compatable with the LA480 loader? Thanks for the help!
   / bucket compatability #2
If it is a pin-on bucket, you probably don't have much choice but to find the original. If you are able to fabricate, it is more likely you will find a bucket from something else, and then you will have to cut/weld your brackets on it. An even better route would be to make/buy a ssqa (skid-steer quick attach) bracket for your loader arms... that way you can use any skid-steer bucket, and it also opens you up to world of attachments.
I also think there are places out there (everything attachments may be one of them) that will custom build you a bucket if you give them the specs of yours. Look around, there are probably other fabrication places in your area that will either build you a bucket or modify one to work.
Thanks so much.
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
15 FT Trailer (A50322)
John Deere 825i Gator (A50514)
John Deere 825i...
