Dredwolf
Bronze Member
Now that I finally have a working MF 250 with a working FEL once more, I have 3-4 years worth of logs, limbs, downed trees, etc to finally move. I bought a set of Paynes Forks years ago, but I always had trouble with them moving from any side pressure, etc.
The forks themselves are plenty strong (label says 2000lbs), but my FEL bucket needs a rebuild after sitting on the ground for several years longer than planned, and the Paynes Forks never seemed contact the bucket properly on the bottom.
I am considering adding chains and ratchet binders to these, are the chain-on forks pretty solid when mounted? I bought an early set of Paynes directly from them, they don't have the contact pad on the pressure screw, so that contact point is barely over a square inch.
Thanks in advance for any advice.
