bucket free floats when tipped down
   / bucket free floats when tipped down #1
twlyons1
Siletz, Oregon 97380 mid coast of Oregon
2011 JD5075M
I have a Challenger 265B, when ever the loader bucket is tipped down to the swivel center point of just hanging from the hinge pins, it just stays there for an aditional 5-7 seconds before the oil builds up in the cylinders and pushes it all the down and back under , i find it very discouraging. when i either continue all the way up or down with the bucket for an aditional 5-6 seconds at its stops (fully extended or retracted)-it will work like it is supose to - instantly both directions, ,,,, seems like air in the system but that has been factored out,,,,,,I was starting to think a seal came loose in one of the cylinders( O-ring) and the seal sliding back and forth in side the cylinder is letting it swing ( in a matter of words)till oil pressure pushes it back to were it needs to be. does not matter if it is cold or hot out, just started or been running for hours.
All the hinges are good and tight, well greaced.
could it be in the loader controll assembly stick? the bucket does drop down when off the ground and motor turned off,,,, about 2 inches in about 15 minutes, faster with heavy loads but not much,,,maybe 3 inches in 15 minutes.
I do have another question about putting rear hydrolics on it but thats for another thread here.
   / bucket free floats when tipped down #2
Have you tried "bleeding" the system? Hold the bucket in "fast dump" for a few secs. and see if it helps. Also if you run the loader at low rpms it might tend to aggrivate the problem you describe.
   / bucket free floats when tipped down #3
The "problem" most likely is the regenerative function of your FEL valve. Read THIS post from Kubmech and see if it helps explain it better than I can.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
