Bucket Will not Curl
   / Bucket Will not Curl #1
chiselhead
umatilla
ford 1920/ 7108loader
Hi Guys Im New To The Site.I Have A Ford Model 1920 With A 7108 Loader.This Weekend I Was Moving Some Dirt,I Dumped A Load And Tryed To Curl The Bucket Back And Nothing Happened.It Sounded Like It Put A Strain On The Motor.HD Oil Was Alittle Low So I Topped It Off.Still No Curl.I Have Had It For About 5Years,Have Never Checked The Filter Screen And Dont No Where It Is Located.Any Help Would Be Appreciated.
   / Bucket Will not Curl #2
double check any quick-connects attaching the FEL, best to uncouple, clean and reconnect
   / Bucket Will not Curl #3
Sounds like its a little shy in the routine maintenance department. Have you lubed the loader arms, pivot points, etc?
Thanks For The Info,After Reading Alot Of The Posts That Seems To Be A Common Problem,And Come To Think Off It I Did Push A Pile Off Brush The Day Before And My Grill Looks Like It Took A Pretty Good Hit From Something.I Will Disconnect And Check Them Out.
Yes Sir I Was A Machinist For 25yrs.Took All Grease Fittings Out Cleaned Old Grease Out Of Holes.Just Repacked Both Lift Cylinders And One Bucket Cylinder.Do You Know Where The Hyd.Screen Is Located.
   / Bucket Will not Curl #6
after checking qd's.. pull return side hose off the curl cyl and see if it is bypassing
I Did Not Take The Hoses All The Way, But I Did Crack Each Of Them Open And Had Fluid.One Did Have More Pressure On It Shot Out Pretty Good The Others K ind Of Just Ozzed Out.
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
2008 Ford Ambulance (A47477)
2008 Ford...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
