Buffalo Hydraulic Turbine debris blower adaptation??
   / Buffalo Hydraulic Turbine debris blower adaptation?? #2
It says it needs 20.45 gpm at 3000 psi.
The PT425 only has 8 gpm at 3000 psi for the PTO.
Even the largest Power-Trac, the PT1460, only puts out 18 gpm, which would be marginal.
Thanks Tim, I was afraid of that.
   / Buffalo Hydraulic Turbine debris blower adaptation?? #4
My boss has one of those puppies. It has a 25hp engine directly driving the turbine. It could almost blow my PT425 across a parking lot. I understand the troops in Iraq use them to blow the sand off of IEDs.
I'm pretty sure a 425 could carry one on the QA. Driving the turbine with the PT hydraulics is out of the question. I'd be afraid to use one in my yard. I only need to move leaves, not topsoil and small boulders.
   / Buffalo Hydraulic Turbine debris blower adaptation?? #5
Yes, it can turn it, but at a reduced speed.
You might get 1200 to 1500 rpm.
Someone has installed a blower on a 422 or a 425. Don't remember who.
   / Buffalo Hydraulic Turbine debris blower adaptation?? #6
Looks like they also have a smaller (.7 cu in) motor available for it which would drop the power needed to ~14GPM.
Aaron Z
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
40' CONTAINER (A51244)
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
