bui
   / bui #1
bui
Pinson, TN
I have a 150 Massey Ferguson with Delco 4 wire with Borg Warner 4 terminal regulator which has two wire round resistors on bottom of regulator. I have had it wired for 20 years and it worked great, but I have had some strokes and can't remember how to rewire it. Does anyone have a wiring diagram for this. I know that #4 post goes to fuel gauge and F goes to F on alternator. There is a R on the alternator and the external post is the output from the Alternator through the amp gauge to the negative side of battery I think. I just can't remember the middle two wires on the regulator. I assume the R on the alternator plug is the exciter wire. Which wires goes to the middle two terminals? Thanks for any help.
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
