Build a set of steel wheels Save my rubber
   / Build a set of steel wheels Save my rubber #1
KingDelta5
Denham Springs Louisiana
John Deere 790 1949 cub 1975 cub 1948 super A 1950 super A 1967 140 High Clear
I am thinking I would like to build a set of steel wheels for my jd 790 .
I am in the process of clearing some land and i know i am gonna get whats coming to me .
I could aquire a spare set of rims and some steel and fabricate a set . Never the less ! I think a set of steel wheels would be great in the woods and fields . My only worry is the shock load imposed on the tractor for lack of cushion of the tires . But shock load might be minimal . Especialy on dirt It has been done before and i wonder why you never see steel wheels now ? might save a lot on tires
   / Build a set of steel wheels Save my rubber #2
Do you think you will have a problem with thorns are sharp objects of some sort? If I was concerned about that I would put foam or something in the tires so they wouldn't go flat before I would go steel. I doubt you would ever want to go on the road with steel.
There has to be a reason nobody goes with steel anymore, maybe it's just not a good idea.
Thorns stumps and stobs oh yea ! And no tellin what ! I don`t think i`ll ever go on the road with my tractor . It might be we don`t see steel wheels because it would be bad for tire manufactures ! If they are really not needed . I seen a ad for ford tractors during ww2 Ford sold steel wheels as a primary option because ot the shortage of rubber for the war effort ! Might work great on dirt except for a bumpier ride ? Oh yes ! I`m planning on keeping my normal rims and tires ! It is just that I think steel wheels might be a good option when you know you gonna get whats comming to ya ! Another thing it might be is steel wheels do play **** with roads !
   / Build a set of steel wheels Save my rubber #4
The amish run steel around here in some of their equipment. I dunno if its a religious thing or what. The only thing I would very strongly caution you about is remembering that Rubber tires slip a little bit when they catch a root. A steel tread will not let go unless it tears through something. You might be looking at the sky or 180* the oher directions very very quickly. I think it could be done, but as deere suggested, I would look into foam filled tires and possibly some ring chains like the skidders use?
   / Build a set of steel wheels Save my rubber #5
Maybe the guys at the local junkyard or landfill might have some suggestions. I see these types of wheels constantly in these applications.
   / Build a set of steel wheels Save my rubber #6
Any steam engine clubs in your area. They would also possibly be a good resource for information on steel wheels. I think you will find that steel wheels will slip a slide on hard surfaces like rocks, tree branches, etc. faster than rubber tires will.
   / Build a set of steel wheels Save my rubber #7
I would foam fill your current wheels before I went with steel. They will ride much better and wont slip on hard surfaces.
Aaron Z
   / Build a set of steel wheels Save my rubber #9
Aaron Z
X's 2, I've used the "Green slim" and had super results clearing mesquite trees. Cheaper than steel these days anyhoo.
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
