Building a "chisel plow" for CUT.
   / Building a "chisel plow" for CUT. #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
Building a \"chisel plow\" for CUT.
OK, its really a small chisel plow. I am putting together a 3-POINT HITCH garden tillage tool from parts off an old field digger. It will be pulled by a jd4100, 20HP 4wd hydro. I think I can pull 7 tines thru the garden, expecting to take them to maybe a foot depth after a couple passes. Sound reasonable? these are the 2" wide tines (are they called danish tines?, can't remember). They are each spring loaded to the frame. I have all the materials now and will start this weekend, pictures then. If anybody has any feedback on the 7 tines, let me know. I was going to use 9 tines, but started to get nervous. I want to be able to pull it. I have turfs, btw. And can have the loader on for more weight. ThANKS.
   / Building a "chisel plow" for CUT. #2
Re: Building a \"chisel plow\" for CUT.
So is this like a 3 row cultivator?
Brinly-hardy.com show a cultivator that uses 8 shanks and are typically used on 20hp garden tractors. Based on that, Id say that go with nine shanks.
   / Building a "chisel plow" for CUT. #3
If you're talking a real chisel plow I doubt that a compact could pull one tine much less seven. A cultivator is much less aggressive and would be more suited to a compact. Here's a pretty serious chisel plow with some serious horsepower in front of it
More at Sunflower /forums/images/graemlins/smile.gif
   / Building a "chisel plow" for CUT. #4
I have a B7500 with r4's and with my neighbors 4 tine chisel plow i will still spin out before 12". I would not go with more than 4 and put them at least 1 foot apart as a minimum. Also it would depend on soil type.
   / Building a "chisel plow" for CUT. #5
Rule of Thumb for a real chisel plow is 1 shank per 10hp. But that is much deeper (there is a reason they are called subsoilers) than what Jim is going. I also think that Rule of Thumb starts at 40-50 hp, i.e., a 20 HP CUT won't have the grunt to pull one even if the rule says it can pull 2. At the 1' depth, that's a cultivator, not a chisel plow. No matter what the source of the teeth/tines/chisels. You might be able to pull all 9. I doubt it, but make the frame long enough to give a place to put them. If you can't pull it, a torch or sawzall will solve your oversized frame problem. I also expect soil conditions will have a large impact on your pulling ability.
Sounds like a /forums/images/graemlins/cool.gif project. Always neat to have the parts, and the ability to put them together into something useful.
   / Building a "chisel plow" for CUT. #6
Jim do u have a box blade w/ rippers?
If u do shorten top link and drop rippers down and try this.
It will only go about 6" deep but will give u a feel for # and size of shanks.
our chisel plows go 9-12" deep, use to break up hardpan below moldboard plowing
sub soiler goes 12-24" deep, shatter and lift soil profile
Field cultivator goes 2-4" deep, for leveling instead of discing
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
