Building a Debris Fork
   / Building a Debris Fork #1
rdrawdy
I would like to build a debris fork for my FEL to pick up small brush piles. I have a BushHog FEL. I also have a blank FEL mounting plate already. I am thinking about welding rebar to the plate for tines. Any suggestions or better ideas before I get started? I am a beginning welder and enjoy taking on a new project. I would appreciate any advice.
   / Building a Debris Fork #2
You've got a good idea but I would think the tines would need to be smooth.
   / Building a Debris Fork #3
I'd use rebar for tines but I'd bolt on with u bolts or studs welded to the bars 'cause they'll inevitably get bent & bolt ons are easier to change. MikeD74T
   / Building a Debris Fork #4
Thanks for the advice guys. It is good to have suggestions like this BEFORE I start the project. You mentioned some things I hadn't thought about yet.
Never knew what a buckrake was. This looks just like what I am looking for. I was able to "Google" it also and found a lot of new, helpful info. Thanks for the advice and education. The video of the horsedrawn one said cost was $90 - wish I could build one for that!:laughing:
   / Building a Debris Fork #8
I made a set of four, 5 feet long, brush tines from 1" black pipe. Mistake. They bend at the slightest bump and heating/straightening them will eventually cause them to completely fail. I would think re-bar would bend even easier.
The second set was for a BX, 4 feet long, and made from channel iron and have held up much, much better. Plus, they can be used as pallet forks.
Thanks gwd for the pictures and advice. Your pictures give me some good ideas about design.
2020 KUBOTA RTV...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
TEST BID LOT (A50774)
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
