BURR MILL/GRIST MILL
   / BURR MILL/GRIST MILL #1
BHD
Veteran Member
easten Colorado
JD 4020
Has any one ever made one?
If so what did you use for burrs? and where did you get them?
If you did make one how did you power it?
any other tips?
I was wanting some thing for for grinding proso millet, (bird seed) it is about 1/16" in diameter, and want to crack it, it has a hard shell and nearly passes through an animal untouched, and will germinate when excreted, in goats and cattle, so I really doubt if they are getting as much out of it as they could be. Proso millet
   / BURR MILL/GRIST MILL #2
What kind of volume are you looking at?
There should be commercial ones available.:)
Intermech for agro machines
Consider the cost of building versus buying. You may find some used ones but usually they will be larger and require quite a few HP to run.:)
I can locate antique units with no source of any parts,
or new that cost in the $600 on up for about a unit with a 5" burr, there seem to basically be two units made
CS Bell Power Gristmill ~ Choppers/Grinders
and Meadows which is a 6" unit, http://www.meadowsmills.com/steelburrmill.htm
Steel Burr Gristmill Grain Corn Grinder Mills at Pleasant Hill Grain
and if one buys the complete unit your looking at $1200 to $2700+, and it out of my budget, so using the mills model which is a weldament looks like a fairly simple unit,
   / BURR MILL/GRIST MILL #4
I have had C S Bell grinders and they are beautiful. They can be bought at Lehman Hardware in Kidron, Ohio and parts from them or the Bell Co in Ohio.
These look simple but require small degrees of adjustment difficult to obtain and different burrs depending on material. Oil-type seeds need special burrs.
It would seem these would bedifficult to build and just buying a modern unit would be cheaper and more satisfying.
Bell sells one that can be hand or vee-belt pwered that can really turn out a volume and should maybe cost $600
It is referenced in the above thread--and here--
http://www.enasco.com/product/Z08247N
Sixdogs thanks for the recommendation and the info,
This is what I came up with, and it has 6" burrs and uses the "la milpa" burrs from C S Bell,
drawing
parts
basic frame
test assambled before painting,
painted,
nearly done and grinding,
done with stand and belt guard,
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
