Bush Hog 2615L- installing protective washer on output shaft
   / Bush Hog 2615L- installing protective washer on output shaft #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
Hey guys. I had to replace the oil seal on the left wing gearbox output shaft. From the bottom I pushed the seal in far enough to pass a slight groove cut into the housing, almost something like an inner snap-ring would go in. But instead there is a metal protective washer with an outer lip ring that seems to go into the groove. However, I don't see how I can get it up to the groove without force which would bend the metal protective washer. Imagine it is like placing an inner snap-ring in with a rigid snap-ring.
My description makes paints a perfect picture for me, but I'm guessing it's not the same for you. Just for description, imagine looking straight at the bottom of the gearbox. Think of it as a 4" piece of pipe with 1/16" wall thickness at the very end. Then going deeper into the pipe just a slight distance, the wall thickness increases to 3/16" with the extra thickness to the inside of the pipe. So if it was 4" O.D. pipe, the end would be 3-7/8" I.D. due to the 1/16" wall thickness. Then slightly farther into the pipe, the I.D. decreases to 3-1/2". So the decreased I.D. leaves a shoulder/lip inside the pipe. The inside of the pipe remains 3-1/2" the rest of the way except for the "snap-ring groove" that is cut 1/16" deep around the inside of the pipe. This groove is 1/2" deeper into the pipe than the first lip.
Now the protective washer measures 3-5/8" O.D. including the outer loop ring. It will easily fit in the end of the pipe that measures 3-7/8". But it hits a brick wall where the pipe reduces to 3-1/2". I need to get this ring another 1/2" deeper into the pipe so that the outer ring will fit into the 1/16" groove where again the inside measures 3-5/8". So how do I get it in?
It may be easier for someone to disassemble theirs rather than imagine my description. Hopefully someone is familiar enough with this to help.
TIA
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
SKID STEER QUICK ATTACH HYD COLD PLANER (A54756)
SKID STEER QUICK...
Hydraulic Hose Crimper (A50775)
Hydraulic Hose...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2019 RAM 2500 Crew Cab Pickup Truck (A55788)
2019 RAM 2500 Crew...
