Rotary Cutter bush hog 296
   / bush hog 296 #1
new2tractors
Columbia, SC
JD 5105
I was looking at getting a medium duty cutter for my '99 JD5105. Bushhog says minimum 45hp for the 296 and the tractor is a 40hp. Is this too much cutter for the tractor? Would it be better to get the 295?
   / bush hog 296 #2
I've got a 286 Bush Hog. (Same mower essentially, just older deck design.) I use it primarily on one of 2 tractors. One is 47hp (pto) other is 40hp. Both work just fine in even the heaviest of brush and weeds. 40HP is enough for normal use.
   / bush hog 296 #3
Mornin New2tractors,
I have 5ft Bush Hog 286 and run it fine with a 32hp Diesel, probablly could run a 6ft at times. Im just cutting field grass for the most part !
BTW Welcome to TBN !
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
2016 Bobcat S850 (A50120)
2016 Bobcat S850...
Diesel Forklift (A51691)
Diesel Forklift...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
