Bush hog 6163 gear box on 306
   / Bush hog 6163 gear box on 306 #1
JDOrrell
John Deere 5065E
Picked up a Bush Hog 306 with 6163 gear box at auction. All seems to be there but in pieces. The horizontal portion of the driveshaft is assembled. The vertical part is in pieces which includes a gear. I first thought it is the gear for the vertical shaft but since it looks just like the gear on the horizontal shaft, which btw is pitted, while this separate gear is not pitted, I wondering if it is was bought to replace the pitted gear on the horizontal shaft. If so, then I would be missing a gear for the vertical shaft. Question: are both gears the same?
   / Bush hog 6163 gear box on 306 #2
It appears they both are the same 17 tooth gear making it 1:1 ratio.
This is listed as a set, but price seems too cheap. Call Messicks to verify: 717-367-1319
6122BH GEAR MINTER SET $188.72
Thanks,
I will make the call.
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
CAT RM-300 (A50854)
CAT RM-300 (A50854)
1996 Eager Beaver 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
