Bush Hog es2052 Zero Turn
   / Bush Hog es2052 Zero Turn #1
23putts
Kubota B6100D
Hi all, first post. Hoping you guys and gals could give me some advice. I have an opportunity to trade for a Bush Hog es2052 Zero Turn with 14 hrs. From my understanding it is the Estate Model, meaning not commercial grade. Does anyone here own one and would be willing to give me your opinion? I would be using the mower for residental use - 3 acres
Here are the details of the mower:
2010 Bush Hog es2052 estate series zero turn 52" deck 20 hp kohler courage14 hours
upgrade suspension seat very comfortable with arm rest
Blade Tip Speeds Of 17,500 FPM Rugged Hydro Gearョ ZT 2800TM Transaxles MagStopTM Electromagnetic Clutch Rated At 125 ft lbs
Patented Quick FootTM Deck Lift System Durable Cast Iron Spindles Greased From The Top 10 Gauge Welded Steel Decks With Reinforced Lip
Powder Coat Paint Self-Contained Hydraulic System Genuine Bush Hog Blades
菱eavy Duty Commercial Size Engine Air Cleaner
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
Pull-Behind Ripper Attachment (A49461)
Pull-Behind Ripper...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
