Tiller BushHog Tiller Problem
   / BushHog Tiller Problem #1
IndianaPaul
Southwest Indiana north of Evansville
NH TC45D
Have used a BH brand Tiller (RTS 74 w/slip clutch) behind my TC45D for the past year with no problems/trouble. In fact been very pleased with it (has been used 19.3 hours). Tonight was diller to put in some food plots, when after about 30 minutes it started to smoke. Shut things down to check it out and found that the driveshaft running from gearbox to chain was toast at the point it enters/connects to the chain. Looks like bearing went bad, monkeyed up the flange around the connection a bit as well. I've been meticulous in greasing, lubing, etc.. on the unit. Have never hit any roots or large rocks with it. Am assuming the bearing just went bad, any other thoughts out there?
Anyone out there running similar units have a problem like this? Just curious. Am off to the dealer in the morning to order the parts to fix.
IndianaPaul
Well, talked to the dealer yesterday/let him look it over. Said clearly the bearing had failed and was the first time he has seen one go like that. Even though it is out of warranty (only a couple of months) he is 'stretching' the warranty as he said it should not have failed, he ordered parts same day & I pick it up tonight. Less than 36 hour turn around during planting time is not what I expected! /w3tcompact/icons/smile.gif
IndianaPaul
   / BushHog Tiller Problem #3
IndianaPaul,
Perfect example of the benefits of buying local.
Buck
12in Backhoe Bucket (A52128)
12in Backhoe...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2024 WABASH STEP DECK TRAILER (A51222)
2024 WABASH STEP...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
