butchwalker9
   / butchwalker9 #1
genesis12
Ridgeville, SC
JD4300
Can someone help me with my JD-4300 it won't start unless I remove the fuel cutoff solenoid, push in the plunger and replace the solenoid. This is very time comsuming so I bought a new one replaced it and it worked for about 3 months. Took the original one replaced it back and it worked for about a month. I have tried moving around the fuel cutoff relay and that didn't have any effect. HELP!!!
   / butchwalker9 #2
It has 3 wires red white black .red should have power with switch on .white wire has power on it when you go to start the engine is the only time it has power on it. It is what pulls the sol in red holds it after it starts. You need to check to see if you are getting power to white wire with switch in crank position.
2015 Ford F-350 Utility Flatbed Truck (A51691)
2015 Ford F-350...
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
2025 CFG Industrial M-AG (A50123)
2025 CFG...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
