BX-1500 Hydraulics Question
   / BX-1500 Hydraulics Question #1
DenisM
Bronze Member
Harford County, Maryland
Looking for one now.
I was thinking about getting a front mount snow blower. The one I was looking at requires hydraulics to make it work. It is driven by the mid PTO; but needs a joy stick to lift it.
I have a load but the joy stick is attached to the loader. So when the loader is removed, the joy stick goes with it. I have been told that there was a second option for these small tractors where the joy stick stays on the tractor; any body have this setup?
   / BX-1500 Hydraulics Question #2
I was thinking about getting a front mount snow blower. The one I was looking at requires hydraulics to make it work. It is driven by the mid PTO; but needs a joy stick to lift it. I have a load but the joy stick is attached to the loader. So when the loader is removed, the joy stick goes with it. I have been told that there was a second option for these small tractors where the joy stick stays on the tractor; any body have this setup?
Well you have an older unit. It wasn't an option it was a redesign. You can still use the blower on your tractor but you have to take the loader off in a way that leaves the controls and upright post on the tractor. This means knocking out a pin that wasn't really intended for regular removal. It's the one that holds the loader arm to the upright on the right side. I know there were a few people here that we're doing this so maybe one of them could supply a picture.
Sent from my iPad using TractorByNet
   / BX-1500 Hydraulics Question #3
You have several choices.
Leave the valve on the loader when it is removed.
Make a new mount and remove the valve from the loader arm and install on the new mount.
Make a new valve mount and order a new loader valve for about $241.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
New/Unused CFG Industrial H15R Mini Excavator (A51573)
New/Unused CFG...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
