splotkin
Well, It happened today. I was driving on the street and there are still some sticks along the side of the road from the Ice storm we had in December. I am not sure how it happened but a stick got into the hst fan and crunch!!!!!
I have looked at most of the posts about this happening. I know that some of the BX like the BX 24 have no room to get the fan out. Does anyone have any experience changing out the fan specifically on a BX 1850? Is there enough room to loosen the engine mounts to get the new fan in and out? HELP
I do not have a garage and will need to have the dealer do it. Just hoping I can show him something to suggest a less time consuming way to do the job.
What I do not understand is why there is no replacement fan with a split hub to allow you to bolt it on without having to slide it off the end of the shaft. I used to work on automatic car transmissions. They had something called a quick band. It allowed you to replace a snapped transmission band by snaking it around the shaft instead of having to pull the shaft.
Scott
Scott
