149owner
Well I'm still trying to decide between an ATV plow attached to the FEL or using a back blade. I've never had to use the 3 pt hitch before and looking over the manual I see there is no "float" position for it like the FEL or once the blade touches the driveway do you put the lever in the neutral position? When you adjust the lowering limit, do you drop the blade down to the driveway and then set the locker to that point so there is no pressure on the blade or have a slight down pressure by setting the locker so the blade is actually trying to go down a little further? Would you recomend the King Cutter regular 5' blade or the XB 5' blade for the BX 2200? Thanks.
