BX 2200 FEL Snowblower Valve Conversion
   / BX 2200 FEL Snowblower Valve Conversion #1
NY_Yankees_Fan
Veteran Member
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
I have a 2002 BX 2200 with a LA211 FEL. Each winter and spring I have to remove the loader valve from the FEL and mount it on the tractor to operate the snowblower quick hitch, see photos below. It is a royal pain to get the pins out and the valve off the loader and remount each spring. I can see why all newer versions have the loader valve mounted on the tractor at all times. Today I picked up a loader valve via Craig's List and all mounting hardware for a later version of the BX2200 where the loader valve stays on the tractor. The valve was used with a front blade and quick hitch. The seller upgraded to a FEL and had to change out the valve, hence my find, been looking for a awhile, 3 hour drive 1 way and $150 and the valve was mine.:D
My spring project will be to convert the loader valve I picked up today to mount on the tractor when using the snowblower. I will leave the old FEL valve on the loader permanently and not have to take it off on each spring anymore.
So my question is for those who have my old set up, have you done this conversion?? If so, how did you mount the valve, plumb lines, etc.
Existing Valve Set Up Right Side Below
New Valve Below
   / BX 2200 FEL Snowblower Valve Conversion #2
I believe I have the same set up as you. BX2751 Blower, LA211 Loader, joystick comes off with the FEL. I bought the snowblower used and am trying to hook it up for the first time. For now I want to use my valve on my FEL and pull the pins on the arms to keep the joystick on my tractor. I was hoping you can tell me what ports do I use on the valve (Red Yellow White Blue Green go to bucket). Did you put disconnects just off the valves? I would like to install a seperate valve in the future like you picked up but I need to work with what I have for now.:confused:
Mike,
I am on the road this week will be back late Friday. Saturday I will take photos and give you the order of the hoses.
Tom
Mike,
Looking at the valve on the tractor the hoses for the FEL are as follows:
Left Top: Blue
Right Top: White
Left Bottom: Red
Right Bottom- Yellow
Hope this helps, if not ask.
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
1042 (A50459)
1042 (A50459)
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
