Bx 2200 front axlel leak
   / Bx 2200 front axlel leak #1
maddog69
Kubota BX 2200 in Pa. Kubota Bx 1870 Fl.
Hello, I have a year 2000 machine with 630 hours on it. Lots of FEL time. I developed leaks in the front axle, looks like a main joint where it joins the axle. Probably a worn seal. I'm not very mechanically inclined....is this something that a person with limited experence should attempt? Thanks Brad
   / Bx 2200 front axlel leak #3
I have the same machine with a few more hours on it than you. It was leaking a small amount. I read the threads hear and used Valvoline 75w-90 full synthetic gear oil. 50+ hours later after change no leak. Be sure to take caps off the top of both hubs so they fill, I put the oil in both sides and after the fill drove it around for a few minutes and re checked the level. Good luck, was the easiest fix I've done. Dan
LOT LOCATIONS (A52577)
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
Hay Wagon (A50515)
Hay Wagon (A50515)
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
