BX 2200 too small for a front broom?
   / BX 2200 too small for a front broom? #2
No, Yes...
Rear (3PH) brooms would be cheaper though.
   / BX 2200 too small for a front broom? #4
The BX2537 sweeper should mount nicely to the BX2200 with the quick hitch and mid pto driveshaft. I recently added one to my bx23. It is a nice setup.
   / BX 2200 too small for a front broom? #6
Anyone run a 48" rotary broom off the front? Does it use mid PTO?
Don't have much to add on this subject, but I read that you were looking for a front blade a while back. If you get a broom they use the same quick hitch sub frame so yow already have half of what you need for the blade.
So the quick hitch is a seperate piece that mounts on front to facilitate easy hitching of small front implements?
   / BX 2200 too small for a front broom? #8
Yes..... for attachments that are designed to be used w/quick hitch
   / BX 2200 too small for a front broom? #9
Same quick hitch for the front blade, sweeper and snowblower.
   / BX 2200 too small for a front broom? #10
Builder said:
Cool. Does it take long to mount? :thumbsup:
A few minutes each for the quick hitch, driveshaft and sweeper. This time of year I leave the quick hitch on in anticipation of using the sweeper and snowblower for snow duty. I leave it there even while using the loader.
2019 Bobcat E45 Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E45...
M & M Grain Drill (A50515)
M & M Grain Drill...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
Lull Highlander...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
