leonz
I think you need to understand that Pronovost and Puma (made by Pronovost)
are 2 different blowers.
different models only
The Pronovost is a sort of commercial blower, $$$$, and the Puma competes with say a Martin Meteor or Frontier, Kubota and so forth.
farm duty and also used for residential
Frontier has a 24" 4 blade impeller. The Puma has a 20" impeller. I'll take the Frontier everytime. And, I just purchased a 64" Frontier that weighs 505lbs. for the great price of $2,100.
The Puma weighs 382lbs. for God's sakes.!! How can you say the Puma is a heavy build.??
No sheet metal or thinner steel.
If your comparing a true Pronovost to Frontier and Kubota....That would be comparing apples to shovels.
no not really, its comparing a well built excellent proven design to shovels.
Can't beat that with a stick.!!
They have a lot of happy snowblower owners and you cant beat that with stick and a huge following.
The Pronovost family name goes on every snowblower or other farm implement they build and the pronovost family has been building farm machinery and snow blowers since 1953 if I remember correctly
The PRONOVOST snowblowers have 7 sizes for the PUMA in Group 1.
The PRONOVOST snowblowers have 8 sizes for the line in Group 2.
The PRONOVOST snowblowers have three snowblowers in group 3.
The PRONOVOST snowblowers have 2 units in inverted models
The PRONOVOST snowblowers have 4 models in the XPRO line models
There is nothing wrong with what I said period. They are well built whether you buy a small "Puma" or the larger units with full welds and reinforcement where required.
The XPRO units are capable of giving you bare pavement with powder snow by acting as a back drag plow and scrape or snow plow to allow you to dispose of it and it can also be used as a back blade as well
The front opening cutting height is 24.5 inches tall from the ground to the top of the shroud allowing you to take 24.5 inches of snow depth into the cross auger and then to the impeller.
They use 540 RPM very effectively using the tractors power take off and offer a front mounting option for 540 rpm implements with a Hardy front mounted three point hitch for rear mounted attachments to allow easy use of these attachments up front to add more utility for a small HP tractor and allows you to use a rear blower, flailmower, or disc mower up front with ease to make smaller tractors more usefull with rear attachments with PTO systems.
The Frontier line was established as a way to offer the john deere line to the consumer at lower cost to the consumer because they were losing sales revenue with thier product line.
All depends on your worry level and knowing something will handle snowfall that may wiegh more than 21 pounds per cubic foot and have remove it and get rid of it.
Gear boxes fail, chains break, the sidewall steel on some blowers flexes and binds the cross augers and causes problems with removal of heavy snows and banks.
The front blower garden tractors and sub compact utility tractors to offer the consumer a way to remove snow
and thats all it is.
The Rad Kubota front blower was designed for a consumer need by using the mid mount PTO and an underbelly mounting frame with a reduction gearbox for the snowblower.
Our wheel horse has a belt drive via the front for the belly mower and if we had a blower it would have a geabox on the blower, your reducing the higher mid mount PTO speed to the gearbox on the blower to enable the chain drive for the cross auger and the pass through to the impeller shaft.
Potato, Potatoe, set the cruise control while you are in reverse and blow snow and cut banks away, theres no reason an extended chute and chute cover cover option cannot be used either to avoid issues of snow blowing on you while working.
leon
