BX 25 - Throttle not staying in high/fast position
   / BX 25 - Throttle not staying in high/fast position #1
oklandist
Kubota BX25
Hi all,
Recently it seems to be having an issue with my throttle level on my BX 25. I place the throttle level in the fast/full position and it idles at around 3300 rpm and then seconds later the levers starts to ease up and move to about 2700 RPM. It will not stay on the high throttle. Is it just a matter of tightening the nut under cover where the lever connects to the cable?
thanks
   / BX 25 - Throttle not staying in high/fast position #2
no there is a metal clamp near the dashboard holding down the throttle cable that just needs a little finessing to tighten up to hold cable better.
   / BX 25 - Throttle not staying in high/fast position #3
After over 200 hrs my BX2660 throttle lever started doing that. As I recall there was a nut under the dash that solved the problem for me. Cheers, Mike
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51242)
TAYLOR TDF-60S...
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
UNUSED JCT QUICK ATTACH 74" VIBRATORY ROLLER (A51244)
UNUSED JCT QUICK...
2006 Ford F150 (A50323)
2006 Ford F150...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
