BX 3PH valve
   / BX 3PH valve #1
bikemiser
Bronze Member
East Central Illinois
Kubota BX1830
I notice that the new BX has a 1/4" hyd. valve. Is previous BX hyd. valves just full up or full down with no way to stop in between?
   / BX 3PH valve #2
On the older BXs the 3ph vaqlve works similar to the way your fel valve does. pull back and it goes up let go and it stops. I am not all that clear on how a1/4 inch valve works but it is still not position control where you move the lever a little bit and the 3ph moves a little bit. In other words it moves in direct relation to the position of the lever. Move the lever three quarters of the way up and the 3ph will move to that position, three quarters of the way up.
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 66"...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
