bx1500 50hr service
   / bx1500 50hr service #1
oledocward
north carolina
kubota 2350
I just finished the 50 hr service on my bx1500--no problems, thanks to good advice from this forum, however, when I checked the transmission fluid dip stick, it was dry--I put in the 2.7 gal without a drop spilling and there are no leaks. I've run the tractor and after running, there is fluid on the dip stick. Is this thing like a car transmission--i.e. you run it until it's hot before checking? I'm hesitant to add more fluid. Any advise is appreciated.
   / bx1500 50hr service #2
You are correct. All fluid should be checked when hot to allow for thermal expansion. Even engine oil dipsticks will have a Min/Max marking to allow for this. Junk...
Thanks, Junkman--
I guess that in the past when I checked the fluid level, it was warm.
I took the mmm off today and put the fnl on! Now I can do some real tractoring!
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
