BX1500 mower deck removal
   / BX1500 mower deck removal #1
mbabbitt
Salem, Oregon
Kubota BX1500
After initially posting this, I see that the question has been handily addressed.
"I suppose I could figure this out; but if there are particulars one ought to know about, perhaps they will be forthcoming.
Where is the best place to start, in removing the deck? I see a number of possibilities.
Thank you.."
   / BX1500 mower deck removal #2
Park sideways on a slight hill. Lower the mower to the ground. Release the front bracket and remove the link to the mower. Return the bracket to lock position. Pull the spring pins at the rear of the deck to disconnect from the lift arms. Raise the lift arms all the way to let you get at the pto shaft. Using 1 hand on each side of the coupling squeeze the collar firmly toward the coupling and pull and wiggle the assembly to get it to move off the pto spline. That last can be the hard part. [Make sure you lube it well before reinstalling the mower.] Pull the mower out the downhill side. Park the tractor downhill of the mower to reinstall. This way you dont have to fool with swiveling the wheels.
larry
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A51572)
2019 International...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
