gilldawg79
2007 BX1850
I pulled the belly mower out and tied up the mid PTO stub shaft up to the bottom. I had previously move the selector to the rear PTO only. I致e run this tractor with a small bush hog like this many, many times. I know it痴 not ideal, but it痴 never been an issue until Saturday.
I unloaded the tractor and bush hog and went to cutting. Somehow, within 25 feet of the trailer, the selector moved into the mid/rear PTO selection on the lever and it went to whipping around under the tractor. I smelled the fluid and loaded it right back up where all the rest of the fluid drained out.
After inspection in the field it just looked like the stub shaft just beat the filter up. Today I replaced the filter and filled it up with oil, tested the function of fwd and rev and raised the lift arms up and down. I shut it down and looked under the tractor and fluid is leaking out at a steady drip from the bottom side of the mid PTO shaft.
What have I destroyed? I知 pretty mechanically inclined, but I致e never done any diesel mechanic work. I知 assuming a sea or maybe bearings of some sort?
Help much appreciated!
