BX220 Rear Hydro/cylinder
   / BX220 Rear Hydro/cylinder #1
Chad450r
Bronze Member
I know there are a few posts on here about doing this, my question is can it be used to put down pressure on 3pt impliments with a cylinder of course and what controls this if you add ther rear ports, Now Im very mechanical but no nothing about hydrolics... so be nice :) Thanks
   / BX220 Rear Hydro/cylinder #2
I assume you mean a HTL (hydraulic top link)? If that is what you mean, then the answer is NO, it will not and cannot put downpressure in the 3PH.
There are VERY FEW tractors that can put downpressure on the 3PH's. The main reason is if you do, the it lift's the rear up and you loose all your traction. Weight on the implement is the solution.
Tell us what you are trying to do and we can offer suggestions from there...Was that nice enough:D
Thank you first off! Mostly was wondering cuz I had seen it on a john deere thought it would be sweet to have.
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2017 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2017 CATERPILLAR...
UNUSED JCT DUSTLESS BLASTER (A51244)
UNUSED JCT...
John Deere Hayrack (A50515)
John Deere Hayrack...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
