JMP,
You are right, you wouln't be able to get enough out of the resale to cover the cost of new. I kept my front quick hitch and 54 blade from my 445, too, but my conversion should be easier going to another JD product.
FWIW, I think the design of the JD quick hitch and front blade is outstanding. A good place to start would be to create some sort of template, or at least a semi-tecnical drawing either from the "receiving" points and pins on the hitch, or from the front end of the 445-- which of course you don't have any more. The cost of fabricating the custom hitch should be less than the differential (loss) between the resale value of the JD product and the cost of the new Kubota product, otherwise you should buy the new unit and sell the old. I can attest that your front blade and hitch is in high demand. I have several people on a string who want mine if I can't get it to work on my new tractor. There are at least 2 "Wanted" adds for the 54 blade over at the MSN JD club right now.
Sounds like a good project. I suppose it's possible you'll need longer hoses or new quick couplers. I'm not sure which side of the BX the hydraulic outlets are on, but I'll have to extend my hoses to get to the other side of the 2210. As you know the 445 SCV is on under the left floorboard, and unfortunately, the 2210 is under the right.
As far as the loader mount, it's a do-able thing too, I just don't know if there is anything to model your custom work after. I doubt your Kubota or JD dealer will be much help, other than to sell you any parts you need. There are a few aftermarket companies that make loader arm-mount front blades, so maybe you could find something already designed for the BX to model you project after. With the proper design and quality fabrication, there are good possibilites there too.
I've said this before, but, IMHO, a front hydraulic blade is the way to go for snow plowing,. Sure, there are limited additional uses beyond snow, but its is easily twice as fast as the FEL or rear blade, especially on pavement. When the snow gets above 14"-18" deep, get that loader bucket out because you'll run out of places to pile the snow and your steering control will be greatly dimished with a front blade. Other wise it's a nice "luxury" implement.
Good luck and post some picture if you get started. I'm looking at a few possible things with the same front hydraulic set up as you, so I'll let you know if I find anything interesting.
