BX2200 and plow
   / BX2200 and plow #1
charliek
WI, USA
Kubota BX2200
Does anyone have any experience with a BX2200 using a 3point 1 or two bottom plow. I need to turn up some ground and am reluctant (too poor) to spend the money on a rototiller. it seems to me i could accomplish the same thing with a plow and disc which, around here, are fairly inexpensive and available used. I haven't seen any discussion on this.
thanks
   / BX2200 and plow #2
yes i plow my garden with 12" molboard plow then till with wallk behind tiller.the plow goes much deeper about 8-10". tractor could probobly pull a 14" no problem,but i would not go with a two bottom,powers not the problem but traction is,i do need 4/wd when i go that deep. As for a disc i would only go with 4'.
   / BX2200 and plow
where did you buy the 1 bottom plow?
   / BX2200 and plow #4
Home depot has brinly products up this way,they are cat.0 but fit cat.1,the pins on plow are just a little smaller in size.I picked mine up used,so i'm not sure if pins were changed or not.but to the best of my knowlage they are standard cat.0. brinly hardy does have a web page,cost is very low for new products compared to cat.1 products from a tractor dealer.
   / BX2200 and plow #6
I have a 3 shank all purpose plow, and my Bx does ok here in georgia . You have to work the lift a little because it will sink about 8 ". Then traction is the issue. I also have a 4 ft disc harrow by tufline. I had to add about 250 lbs but it does ok considering this clay is like cement.
   / BX2200 and plow #7
plow first let it winter over then disc or till. i saw a 2 bottom plow yesterday fown the street for a 3 pt hitch for 200 $
   / BX2200 and plow #8
Interesting post to me.. What kind of tires do you have on the 2200. I would think turfs would clog immediately.. Always interested in what the 2200 can do.......
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
Electric Forklift Pallet (A50322)
Electric Forklift...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
