BX2200 - Front blade for plowing
   / BX2200 - Front blade for plowing #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
Anybody have the BX2763 'heavy duty' front blade for the bx2200?
See it here:
http://www.kubota.com/bx1800impl.cfm
It says hydraulic lift and hydraulic angle standard, but then says "Manual blade angle adjustment, 0 ~ 30 degrees left and right".
So my question is, which angle do the hydraulics handle? Is manual left/right OK for plowing snow?
- Patrick W.
   / BX2200 - Front blade for plowing #2
I have the BX2763 blade. The lift is supplied with the quick hitch, and the angle is supplied with a cylinder on the blade. The setup requires a 4-way valve (the BX comes with a 3-way standard), so if you haven't ordered your tractor yet, exchange the 3 way for a 4 way (about a $75 increase for excahnge, very expensive to buy right out).
Be sure the dealer gives you the additional quick attach hoses. These enable you to go from loader to blade qucikly.
I got the hydraulic angle because I didn't want to get off while snow plowing. If getting off doesn't bother you the
manual blade is cheaper.
CATERPILLAR D11T HI TRACK CRAWLER DOZER (A52705)
CATERPILLAR D11T...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2015 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2015 INTERNATIONAL...
2018 JOHN DEERE 410L BACKHOE (A52705)
2018 JOHN DEERE...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
