Oil & Fuel bx2200 fuel gauge
   / bx2200 fuel gauge #1
ping
The fuel gauge on my BX2200 does not work properly does anyone have the same problems. The gauge does not go pass 3/4 full.
   / bx2200 fuel gauge #2
Yes there is a fix for the fuel gauge, the trouble is the sending unit in the tank, mine suffered the same problem and my dealer replaced mine. The other things I know of are a recall on some early BX's for brittle plastic on the fuel junction block under the frame. Also the lift arms and top link of the three point hitch have also been updated on early versions. The best thing to do is contact the dealer you bought the machine from and have them check if the serial # of your machine falls into the range of machines affected by these problems.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2023 John Deere 8R 410 Tractor (A53342)
2023 John Deere 8R...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
