BX2200 gear box leak and hydrolic leaks
   / BX2200 gear box leak and hydrolic leaks #1
golf
I have incountered another leak, this one is the gear box for my 54" MMM. The leak is between the gear box and the belt pulley, has anyone had this problem. Also power steering leak can anyone help me with any recalls on any of these items. Thanks
   / BX2200 gear box leak and hydrolic leaks #3
No recalls that I'm aware of...though some hoses were replaced on request at one time, seems like they had some bad fittings if I remember right.
You are the first one I've heard of with a leak in the gearbox of the MMM. You sure it wasn't overfilled? In any case, I'll bet it's an easy seal replacement...
Good luck and if you replace the seal, make sure you take some pics and post it as a project....I doubt you'll be the only one ever to replace it....
   / BX2200 gear box leak and hydrolic leaks #4
   / BX2200 gear box leak and hydrolic leaks #5
The manual for my 60"MMM says to change the gear box seals every 2 years.
Does anyone actually do this?
   / BX2200 gear box leak and hydrolic leaks #6
2023 Cat 310 Excavator (RIDE AND DRIVE) (A50774)
2023 Cat 310...
Year: 2016 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 222,981 Plate: Body Type: 2 (A51692)
Year: 2016 Make...
2015 TRANSMASTER LOWBOY TRAILER (A52141)
2015 TRANSMASTER...
Unused 2025 CFG MX15RX Mini Excavator (A50322)
Unused 2025 CFG...
Swict 84" Bucket (A50121)
Swict 84" Bucket...
