bx2200 starting problems
   / bx2200 starting problems #1
michaels1
Got used bx2200 yesterday, love it. But this morning, wont start. After a while all of a sudden it starts. Have moved the lever that puts in nuetral many times, anyway. Turned off, and tried to start again, same problem. After an hour it started. Whats going on?? Michael
   / bx2200 starting problems #2
Try moving the lever for the pto. There's a safecty switch on it also.
Dave Perry
   / bx2200 starting problems #3
seems like u have one of the safety switchs that is not making all the time. depending how u hit the seat or the amt. of pressure on clutch or just the movement of u climbing on will make it work. could be any one of the switches. do a search and see if bx owners can pin point it. don't think u have a major problem. although if the tractor won't start when u want it to it is a major problem/w3tcompact/icons/eyes.gif
   / bx2200 starting problems #4
I have a BX2200 and mine would not start one day and I noticed the neutral switch came loose. The switch is under the fender next to the right tire. I took the rear tire off and readjusted it and have not had a problem since.
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Landoll Hauloll (A52128)
Landoll Hauloll...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
2016 CATERPILLAR 335FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
