BX2200 Steering Leak?
   / BX2200 Steering Leak? #1
mvanditta
I have fluid leak problem with my BX2200. The leak is somewhere in the steering assembly (where the four hydraulic lines connect to the steering wheel). I have already had it in the shop to have this problem corrected, but it is back after putting only five hours on the machine. The dealer said it was a bad o-ring, but I believe that something else is wrong with the assembly. Has anyone else had a problem with leaks in the steering? I have only put twenty-two hours on the machine.
   / BX2200 Steering Leak? #2
I had a problem with the steering that was just fixed this week. There is a service bulletin on this. They replaced the hydraulic steering cylinder-bad manufacturer.
See the previous post "BX2200 Steering problem....solved" for more info. Also see the previous post "BX2200 Steering problem....solved...update"
Bob
10' Feed Bunk (A50515)
Coyote Steel Target (A50515)
Coyote Steel...
2014 Chevrolet Impala Limited (A50120)
2014 Chevrolet...
1996 Nissan XE Pick Up (A47384)
1996 Nissan XE...
Bale Ring (A50515)
Bale Ring (A50515)
2014 Isuzu NPR-HD Landscaping Sprayer Truck (A50323)
2014 Isuzu NPR-HD...
