BX23 - Sophie's choice for the winter
   / BX23 - Sophie's choice for the winter #1
ArtyB
I have a BX 23 TLB with a 48" Sitrex finish mower. I cannot get everything into my shed for the winter, so have to make a choice. My plan is to leave the loader outside on a blue stone patio, but covered. Anything I should do to it first? Is there much risk to doing this?
Thanks as always - Richard
   / BX23 - Sophie's choice for the winter #2
I"d leave the car out and put all the tractor stuff inside :) Otherwise, which implement takes the smallest tarp?
All my stuff is parked outside but under an open shed roof. Even so, I spray all the exposed hydraulic rods with LPS3 to keep the moisture off. When I need to use an attachment, I use a lighter lubricant to clean off the LPS3.
I just sort of made that up - what do others do?
Z.
   / BX23 - Sophie's choice for the winter #3
You won't hurt anything, lots of farmers leave all their equipment out though covered is preferable.
I would use only a breathable tarp or you will get a lot of condensation which won't dry off very quick due to a lack of air flow.
   / BX23 - Sophie's choice for the winter #4
...will everything fit if you chain mower vertically in FEL bucket?
   / BX23 - Sophie's choice for the winter #5
Problem with that is most loaders will leak down over a few days. If the shed wall is stout enough, you might use the loader to hang the mower on the wall.
Ian
The mower's not the problem. I cannot get the entire TLB into the shed due to the length and if I pull in with either the FEL or BH and then detach them, I cannot get in with the other attached.
Didn't anticipate the BX23 when I built the shed...
Richard
   / BX23 - Sophie's choice for the winter #7
What id you put the BH or FEL on a dolly and wheeled it to the side then drive in??
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
1266 (A50490)
1266 (A50490)
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
