BX23 truning brakes?
   / BX23 truning brakes? #1
638
Platinum Member
Southern Indiana
BX23
Has anybody considered trying to alter the bx23 brake system to use the brakes as truning brakes? I use my tractor to backdrag a lot and would like to have more directional control. This would also help with snow removal with the back blade. I really dislike having to stop and realign the direction of travel.
ron
   / BX23 truning brakes? #2
Forget it, the BX series uses a wet brake in the drive case. It is located before the differential, so what you propose is just not possible.
Yes, the BX23 has wet brakes. It also has two sets of brake discs, one set on each axle, just like on larger tractors. I think a linkage alteration and another pedal would provide some turning control.
ron
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
20" Sea Container (A47384)
20" Sea Container...
