BX2350 trailer tongue weight
   / BX2350 trailer tongue weight #1
nh_bota
Bronze Member
Southern NH
Kubota B2620
I have some house remodeling to do and instead of renting a dumpster, I'm thinking of renting large open trailer (uhaul 6x12) to park next to the window for the demolition debris (instead of walking it to the other end of the house to a dumpster). I'll have quite a bit of debris, so this would be much more efficient. I can then use my truck to haul the trailer to our dump.
Anyway, I don't want to drive my truck on our lawn, so I was thinking about maneuvering the trailer around the house with my BX. What type of tongue weight would max it out? I have the EZ hitch system and I could use a loaded FEL as ballast.
   / BX2350 trailer tongue weight #2
I don't know what you could actually "get away" with but, if it helps, I have hauled a few ~700# pallets of steel pipe on my cheapo 3PH forks. Full bucket of gravel for ballast, pretty squirrely ride.
Cheers!
   / BX2350 trailer tongue weight #3
Are you pulling it with the drawbar or a drawbar on the 3 pt lift arms? What is your 3 pt hitch capacity on your 2350? I doubt you'll exceed either the drawbar or 3 pt lift arm capacity with a 6 x 12 trailer. I regularly use my homemade 3 pt hitch to move trailers around the yard. I have a 12K gooseneck that weighs 3900 and a 30' camper that weighs about 5800. Both have between 1500 and 2000 tongue weight.
   / BX2350 trailer tongue weight #4
The owners manual for my BX2230 has this figure. Check your manual, I suspect this trailer weight info may also be in yours. I would be more concerned about max trailer weight as the BX brakes are not the best. If you have to traverse any grade I would be especially concerned about max weight. so an over weight trailer does not push you around.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
1964 Mercedes (A51694)
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
