BX24-speed
/ BX24-speed #1
kchear1
Rock Hill, SC
Using a gps unit, has anyone measured their top speed? Manual says 8 mph rated. When first bought, mine actually topped out at 10 mph. But then developed an issue with it dropping to about 6-7 mph after about 2 hours of use. Rep told dealer to replace the all forward pedal linkages with the new BX25 linkages. Since then the mechanical stop bolt is all the way down and my forward pedal is all the way down to the brake pedal. This would normally not be an issue, however, since I'm transporting my loads over a 300 ft distance at a time (over level surface), it becomes very noticeable. Also, my throttle controls the speed of the tractor over the entire range ever since they replaced the linkages whereas I was able to top out at about 3/4 throttle before then. Anyone ever notice this on their tractor?
