c5264 Cofle joystick problem
   / c5264 Cofle joystick problem #1
riverhino
Letts, Iowa
I have a Cofle joystick that I need parts for - any idea where I can find this stuff or even a diagram on how to separate the controller from its casing?
The curl cable connects to a piece of plastic which in turn connects to the joystick itself - and the plastic "piston" sheared right where the metal cable rod ends.
Any ideas appreciated - this is a Koyker loader mounted on a c5264 Montana.
(love the tractor - not impressed with Cofle joystick engineering).
thanks
-Ryan
Turns out the plastic part is a molded part of the cable itself.
Koyker's Service and Warranty dep't has me fixed up with a replacement cable and direction on how to do it - quick shipping and a fairly reasonable price on the cable ($77).
Still not thrilled with the plastic - maybe I'm just old-fashioned but I like steel!
   / c5264 Cofle joystick problem #3
riverhino, can you take the Old Cable to a machine shop and have a metal version of the plastic piston made/attached? then you have another spare incase cable number 2 gives out.?
   / c5264 Cofle joystick problem #4
Hi, I have the same problem, got the replacement cable from NH, but need directions as to how put it on. Thanks
2010 UTILITY DRY VAN TRAILER (A43005)
2010 UTILITY DRY...
2025 Wolverine LHR-TWP80 Semi-Trash Water Pump (A47484)
2025 Wolverine...
2025 Kivel 42in Forks and Frame Skid Steer Attachment (A44571)
2025 Kivel 42in...
Ford NAA Jubilee Tractor (A46877)
Ford NAA Jubilee...
2012 John Deere 700J LT Crawler Dozer (A47484)
2012 John Deere...
2016 GMC Terrain SLE2 SUV (A44572)
2016 GMC Terrain...
