CAB-is rear defrost worth it?
   / CAB-is rear defrost worth it? #11
Will you be doing anything with the tractor that could toss a rock through the rear window? I've had it happen while running a MoCo. Not my tractor, thankfully. Window replacement will be expensive enough without the wire heater grid.
Bob
   / CAB-is rear defrost worth it? #12
I have a JD 3720 with cab. There is no option for a rear defroster. I don't have fogging in the winter. There is a switch to push that will mix outside are to remove the moisture that causes fogging. I don't have a problem with fogging and I assume the Kubota works in a similar fashion. When snow blowing, I will get snow on the rear window that stickes. Easily removed with a rear wiper but I don't have that option. Rear window defroster may help melt that snow a bit faster but not critical IMHO.
If you left your tractor outside in the winter, then a rear window defroster would be of benefit, just like a car.
   / CAB-is rear defrost worth it? #13
I have a B3030 with a cab but without the added rear defoster and have found the system has no problem keeping the windows clear of fog and frost once the engine is warmed up.
I always end up letting the tractor run for a while before snowblowing to warm up the engine and cab, and thats sufficient to defrost things and keep the windows clear from fog. If there was added de-frosting capabilities it might make that warm up period shorter.
NEW Thiessen Track Closer Disk (A55218)
NEW Thiessen Track...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
TEST BID LOT (A50775)
1262 (A50490)
1262 (A50490)
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
