Calling all armchair Horticulturalists!
   / Calling all armchair Horticulturalists! #1
Marveltone
Veteran Member
Somewhere north of Roseau, MN
Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
We have a Maple tree behind the outhouse we dearly love. My wife's parents planted it the spring she was born. Last time I was mowing, I noticed I was getting covered with sticky, white fluffy stuff while brushing against the tree. I took a closer look and this is what I found. The leaves were covered with some white residue, many were wilted, and some even had some fuzzy clumps around them here are a couple of pictures. They're not the best, as they were taken by my phone, but hopefully, you'll see what I mean.
Any ideas?
Joe
   / Calling all armchair Horticulturalists! #2
could be some type of caterpiller/spider web going on. I would cut it out and burn it.
I though I saw some on a birch tree we had, I though someone said it was a
leaf roller caterpiller, but not 100% sure.
I'm wondering if it's either a parasite or a disease. I know the pictures are bad, so the details are sketchy at best. What looks like a cocoon in the pictures really looks more like dandelion fluff in real life. It sticks straight out from the branches instead of wrapping around like a cocoon.
Joe
   / Calling all armchair Horticulturalists! #4
Yeah, pictures leave a bit to be desired, but if I had to guess I'd say that the middle picture is powdery mildew on a silver maple. The other two pictures *might* be woolly aphids, though the second picture seems more characteristic of them than the first.
The majority of the leaves seem to be clean, so there is likely nothing to worry about if this is the case. Neither is terribly harmful unless there are huge numbers of aphids or the tree is stressed.
I'd consult your local arboricultural or agricultural extension service if you want more info...
   / Calling all armchair Horticulturalists! #5
Powdery Mildew (goggle it and see if you think that's what t is}
Not necessarily a big deal. But if it looks threatening......The best thing to do is trim the leaves and collect them then discard or burn. Remove any excess leaf litter away from tree and give it some fresh mulch or good compost.
   / Calling all armchair Horticulturalists! #6
Do you have a county extension agent ? usually you can take them a sample and they will id the problem, often they will even come out to your property.
(1) 225 Gallons of Bleach (A51573)
(1) 225 Gallons of...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
