Snow Can a 2615 HST power a 62" or 72" Snow blower
   / Can a 2615 HST power a 62" or 72" Snow blower #1
Wyld Bill
Central Maine
Mahindra
When I was looking on here there was one guy with a 2615 with a 62" Puma blower. I was wondering how that & other wider snow blowers work on a 2615 HST withe it's meager 21HP PTO output.
   / Can a 2615 HST power a 62" or 72" Snow blower #2
Hi Bill, I replied to your other thread on snowblowers.
   / Can a 2615 HST power a 62" or 72" Snow blower #3
The 2615 HST generally puts out 23-24 pto HP on our dyno, they are underated in the brochures.
   / Can a 2615 HST power a 62" or 72" Snow blower #4
The 62" would be the size I would recommend for the 2615, and it will handle, no problem.
   / Can a 2615 HST power a 62" or 72" Snow blower #5
For sure, I've yet to run into a lack of pto power for any of my implements.
   / Can a 2615 HST power a 62" or 72" Snow blower #6
Bill,
I sent you a PM reply.
To answer your question my 2615HST has the PUMA 64" blower. It would probably handle a larger one. You need to at least cover you wheel tracks. The speed and range you use depends on the type of snow you are blowing. Light fluffy snow you can probably use mid range and move right along. The wet heavy snow may require low range at a slower speed. The HST is great because you set the RPM for PTO speed of 540 and control your movement speed with the HST pedal. On blacktop drives you can set the shoes low, for gravel drives set them high to avoid picking up gravel / stones. It's amazing how fast one little stone will snap a shear bolt.
Wow SWEET!
Thanks guys.
Gonna look for a deal on a 62" blower. OR a STEAL on a 60" blower then if it isn't wide enough I can add wings.
So lets see we got>
RAD/Edneyco/Blizzard made by Bearvac that is 64" for $1938
Pronovost/Puma-64" for ????
Schule BX-62" for YIKES $4300 :eek:
I like the gear drive chute on the Puma,...although I was thinking of using a small ATV winch to turn th echute & I guess I wouldn't be able to do that modification with that one. Hmmmm
   / Can a 2615 HST power a 62" or 72" Snow blower #10
Bill,
I have a 2615HST with a 72" standard sized (not compact) Agrotrend blower on the back. I haven't had any issues blowing the snow, even when it's the heavy lake effect snow. I have actually used my high speed hst setting to blow the snow when it's the light fluffy stuff and haven't had to use the lower gear yet. I have found that the snow will start pushing and coming out the sides before the tractor bogs down and that will make you slow down a bit.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
377672 (A51573)
377672 (A51573)
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
