Can a OC valve be converted to CC
   / Can a OC valve be converted to CC #1
ryanbr
Bronze Member
White 2-105, Cockshutt 770
Valve in question:
https://www.surpluscenter.com/item.asp?UID=2009101516300462&item=9-7725-35&catname=
Price is right, looks like it will work great... wrong hydraulic application. I've seen some kits out there that can convert OC to CC on certain valves.
I understand OC vs CC systems, however I am unsure of the mods needed to convert a control valve.
If anyone knows where to located a similar joystick control for a CC system please let me know. Thank you!!
   / Can a OC valve be converted to CC #2
I would say no, it can't be converted-only because they do not list a CC plug available for it like they do other valves like the 9-7401 Joystick Valve. A call to Surplus Center might confirm this.
Is you need CC and cable operated, you may have to look at the Prince SV series stack valves. You can build the stack to your specs and also get cable and joysticks for them. Page 14 and 15 of the current Surplus Center catalog shows the details.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A51247)
2016 WITZCO RG-35...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2013 Yamaha Golf Cart (A51573)
2013 Yamaha Golf...
Modine Shop Heater (A51573)
Modine Shop Heater...
