Can I change just the 4100 hydraulic/trans filter?
   / Can I change just the 4100 hydraulic/trans filter? #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
...not all the oil, just the filter? I just added a valve, a bunch of hose, two new (old) cylinders, etc. I think it'd be a good idea to change the filter after a few more hours of operation, but obviously the oil is still in good shape. What happens if I swap the filter, how much oil comes gushing out there? BTW, this is a HST tractor, in case that matters to the answer. Thanks!
   / Can I change just the 4100 hydraulic/trans filter? #2
I put a big dent in the side of my filter on my 4100 so decided just to change the filter. The oil comes gushing out so it depends on how quick you can get the new filter up there and screwed on. Naturally, when I was trying to hurry and the oil was pouring out I couldn't get the threads to start on the new filter so I ended up loosing most of the oil by the time I got the new one on.
Oh Shucks, I was afraid that was the answer. Thanks for the quick reply, I will think about it a while.
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
